Topics49,878
Posts837,753
Posts: 246 |
Impressive. My car has been sitting the past month in a Hampshire garage while we relocated from Koln to London. Flicked back the isolator switch and it fired up perfectly. I was half expecting some drain.
That switch is a god send. The garage has no easy access power so a trickle charge is not possible. My prior 3.7 would not have been so easy.
J. Neil
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Indeed....the only problem I've found is that if I use the isolator I have to re-program the radio memory!
Posts: 384 |
Indeed....the only problem I've found is that if I use the isolator I have to re-program the radio memory! you can bring a single cable from the radio to the battery , it's what i have done in my previous car and it work like a charm
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
It is also quiet useful for solving random electrical glitches apparently, good ol Morgan foresight!
Aero 8 GTN #11
