5 members (+8Rich, Pyewacket, B3MOG, Liam1961, Haggispeed), 288 guests, and 40 robots.
+8Rich 92
John V6 49
Posts837,986
The clutch release bearing on my Moss box +8 is squealing so I need to lube it. Never done this before and was surprised when I couldn't find the grease nipple. It's impossible to see down through the hole in the gearbox hump and I can't reach down far enough to feel anything. Am I missing something here? Is there some trick to this? Any assistance will be greatly appreciated.
Thanks
Tom
Tom Morris
1972 Plus 8
1932 Super Sport "Beetleback"
1961 Morris Minor Tourer
1972 Triumph T120V
There is a zerk at the end of the bell housing tube on the inside, top, right next to the bulkhead. Should be a flap and a hole in the tranny cover. Very difficult to access. I ordinarily take the steering wheel off and the seat out to give Myself a bit of room. Need grease gun with a flexible hose. Talk to Ron Theroux about this.
Button
Seattle
Button
As Button says, the grease nipple (zerk) is not at all easy to see. Yes, you can get at it through the hole in the transmission cover, but you need to be sure that the grease is going through the nipple and not escaping around the edge. Flexible hoses on grease guns have a tendency not to sit skewey on the nipple. You could use a mirror and torch after greasing to check for escaping grease. I go to the effort of removing the transmission cover to grease the clutch bearing to be sure that the grease is going where it should. A good mod would be to make an extension so that the nipple is visible just protruding out of the hole in the transmission cover.
Thanks Gents, got 'er done. The zerk is much further down than I had imagined. Tricky job, what with getting the light shining down the hole rather than is your eyes, then working backwards in the mirror. All with your head jammed between the steering column and the firewall. Enough to p**s off the Good Humour Man!
Tom Morris
1972 Plus 8
1972 Triumph T120V
TTC Offline
OXR 5
OXR 5
Button, does this zerk actually lube the thrust bearing, it seem too far back to
do this.
Tony
No. It lubricates the sliding sleeve. The carbon thrust bearing is pressed into the front end of the sleeve.
Pressed into the front end of the piston which slides in the sleeve.
Button
Picky Picky
Button
TTC Offline
OXR 5
OXR 5
So as Button and Tony say this zerk only lubes the sleeve, did this cure Tom's squealing?
I ask cos my 1954 DHC has squealed for the last 14,000 miles?? despite regular greasing.
Tony
Tony
Don't think the issue was squealing.
Button
Button
No, that would be Cameron's fault.
Best Regards
Lang may yer lum reek
