4 members (Hamwich, Mark+4, Alistair, John V6), 281 guests, and 98 robots.
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,437
Bone dry my 2012 except where I got a little close to a push rod tub when I modified the head for the roller rockers, sigh-- but all the better reason to order a set of the new big valve heads which are factory modified
Same for me, just a few drops after a good run, nothing alarming...would not be worried about oldgit I need fill about 250ml oil once a year back in to keep it on the level...
Cheers,
Georges
I
I
I've been using that British Leak-In oil, pour it on the outside of the motor and it leaks in. I usually top up the wiring smoke fluid at the same time, should the wiring develop a leak.
Inge
Originally Posted By MOG42
May 2015 21,000 miles bone dry
Blimey, that must be some kind of record! Where have you been? drive
Andy
I have just a small weeping leak from the small triangular cover to the left of the timing chest cover. Looking at it again it seems that it might be the clamp on the oil line that runs in front of the cover. I will investigate further.anyone else seen this?
kirkusblog.com
1952 Ford 8N
July of 2013, 22,000 miles, no leaks.
No mine weeps from crankshaft seal though ! getting sorted under warranty...
Draggin I have the same leak. See my previous post this thread dated Sept. 8, 2016. It's not any worse.
