0 members (),
362
64
Topics49,849
Posts837,425
Posts: 582 |
Bone dry my 2012 except where I got a little close to a push rod tub when I modified the head for the roller rockers, sigh-- but all the better reason to order a set of the new big valve heads which are factory modified
Posts: 342 |
Same for me, just a few drops after a good run, nothing alarming...would not be worried about  I need fill about 250ml oil once a year back in to keep it on the level...
Cheers, Georges
Posts: 213 |
I've been using that British Leak-In oil, pour it on the outside of the motor and it leaks in. I usually top up the wiring smoke fluid at the same time, should the wiring develop a leak.
Inge
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
May 2015 21,000 miles bone dry Blimey, that must be some kind of record! Where have you been?
Andy
Posts: 2,539 |
I have just a small weeping leak from the small triangular cover to the left of the timing chest cover. Looking at it again it seems that it might be the clamp on the oil line that runs in front of the cover. I will investigate further.anyone else seen this?
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
July of 2013, 22,000 miles, no leaks.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
No mine weeps from crankshaft seal though ! getting sorted under warranty...
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
Draggin I have the same leak. See my previous post this thread dated Sept. 8, 2016. It's not any worse.
