1 members (Montegue),
328
53
Posts837,277
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
...Basically, if anything happens to the tires on the front or the single car tire in the rear, you'll be towed. .... Sorry but that is very duff advice - see the warnings re towing the M3W! NEVER TOW IT! CHeck out last para pp 79 in Peter Dron's book... Sorry, my bad. Should have used "Hauled out by flatbed truck" Which has happened to me too many times.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
...Basically, if anything happens to the tires on the front or the single car tire in the rear, you'll be towed. .... Sorry but that is very duff advice - see the warnings re towing the M3W! NEVER TOW IT! CHeck out last para pp 79 in Peter Dron's book... Sorry, my bad. Should have used "Hauled out by flatbed truck" Which has happened to me too many times. Probably most experienced owners knew you meant that - had my first meeting with the dreaded flatbed last month. [They carted away a wheel for innertube replacement, so it was a bit of overkill... that time]
I wasted more time explaining to the auto club (AAA) that this was a 'car' and that it could be hauled and I would gladly show the driver how to do it and the tie down points.
In all cases (4) it was like reinventing the wheel. again.
Having the car dead on road was bad enough but dealing with dim bulbs on a flaky cell phone connection almost brought me to tears.
Posts: 2,539 |
Glue little fabric washers beneath the Fasteners on your tonneu cover?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Red Leader
Posts: 24 |
These compensator housing 46mm grommets are a snip at £5.00p and are essential to prevent gundge entering the housing..... They are aviation spares and there are only 3 left from the first batch. Don't miss out.......
Posts: 2,539 |
Locktite things... Before they vibrate loose and vanish. such as 1. screws on the Urban Cooling kit.
Posts: 1,490 |
Locktite things... Before they vibrate loose and vanish. such as 1. screws on the Urban Cooling kit. You don't even HAVE an urban cooling kit!
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
Locktite things... Before they vibrate loose and vanish. such as 1. screws on the Urban Cooling kit. You don't even HAVE an urban cooling kit! Well technically I dont have ANYTHING! I'v laid out $65K for an IDEA!
Posts: 1,490 |
Locktite things... Before they vibrate loose and vanish. such as 1. screws on the Urban Cooling kit. You don't even HAVE an urban cooling kit! Well technically I dont have ANYTHING! I'v laid out $65K for an IDEA! Exactly. Hopefully you'll soon find out if you have an urban cooling kit.
