3 members (MavisTheMorgan, sbarracl, Biggle), 171 guests, and 37 robots.
+8Rich 92
Topics49,838
Posts837,294
Page 10 of 10 1 2 8 9 10
Draggin Offline OP
Maybe the Urbans no longer need cooling?
kirkusblog.com
1952 Ford 8N
In Baltimore the Urbans are already cool. The SUBurbans need a cooling kit. The Rurals REALLY need it.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Draggin Offline OP
so far, other than spritzing the front end fasteners with ACF-50, I have done nothing but drive it.
kirkusblog.com
1952 Ford 8N
I've gone around the M3W with a sister product (Corrosion-X). My new best friend. Found some threads that were rusting. Light wire brushing followed by corrosion treatment. Excellent strategy.
When I had the M3W up on a lift for the oil change, took the can around and spotted every fastener I could. I think it will have long term benefits--especially in a vehicle with mixed steel & aluminum. Only the owners of Amphicars might benefit more from it. smile
Probably been mentioned before but check for grease throw out onto inner front disc rotor from overpacked bearings, especially as you reach higher speeds wink
I'm still getting slight splashes from right hand side after 4000 miles, although none ever from the left confused2
Draggin Offline OP
yes I cleaned some off of the drivers side wheel last night
kirkusblog.com
1952 Ford 8N
