11 members (CooperMan, ch44, Graham, G4FUJ, TBM, JohnHarris, Andy, SteveT, TeddyAds, rossocorsa, Mark+4, Morganmike),
182
64
Topics49,881
Posts837,795
Posts: 155 |
On my car’s last outing back in October, I noticed that the misses, the good lady Christine, was experiencing far warmer legs than I was. While she was quite happy with this state of affairs, I felt that I was maybe suffering unnecessarily, so I thought some investigative work was required.
So, a couple of weeks ago I drained all the coolant, and then to give the heater matrix a good flush, I took off both the heater hoses and then connected the garden hose to one of the heater pipes. To the other heater pipe, I connected a length of old garden hose so that it discharged into a bucket. I then turned on the tap and let mains water pressure do the rest. After a few seconds of gurgling and spluttering, several chunks of congealed Radweld (or similar stuff) appeared in the bucket. Success! (The previous owner had a new radiator fitted at some stage, so I assume that he’d put some stuff in the system prior to that to try and cure a leak, but it would appear that the system hadn’t been flushed through sufficiently when the new rad was fitted).
I then reversed the hose connections so that the heater matrix had a good flush through both ways. I then re-filled the system and ran the car for several minutes to make sure everything was leak-free.
But to make sure that the heater was working properly, the car needed a good run – so the other Sunday, and even though the temperature was hovering around the zero degree mark and the roads were wet and salty (but the sun was shining!), I had to go for a little spin. So on with the woolly hat, scarf, thermals and gloves and off we set – thankfully with nice warm legs. With the heater now in full working order, the Simmonds Windstop performing well, and the ski-hat pulled firmly on, I had a nice warm, snug little trip. Even though I had to thoroughly wash the Morgan down afterwards, the 40-mile jaunt was well worth it, and I’m very grateful to the previous owner who chose the full ‘rustproofing’ option!
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue Ex Indigo Blue '99 +4 Ex MogMMX Innovations winner
Posts: 1,597 |
I wondered what happens to rad seal when put in your cooling system. It often clogs everything up but the leak. Glad to hear you have a functioning heater, I was out today and could not do without it.
