1 members (Rex_tulips), 265 guests, and 38 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,354
Members9,215
Rbt Aero8, Salmon, stevends
Page 4 of 11 1 2 3 4 5 6 10 11
drk Offline
The USB port is under a little black plate. You need to unscrew it and you will see the port
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
There is no OBD port available, but you can easily find the location in my picture
M3W willow green,Triumph T100,KTM LC4 Adv./Freer.250R, RD250/RS125DX, Alpine A110
Kurt
You'll need a very small hex key. I want to say it was the 1/16th in.
I purged the adaptive map, got about 15 minutes of driving before the light came back on. The dealer is going to take a look at it. I'll update with what it turns out to be.
Thanks again for the help spelunx.
kwb Offline
Going home from Grindelwald meeting I had my Engine Control Light burning nearly constantly (for more than 1200km's, engine worked without problems). My dealer checked all sensors involved, especially the knocking sensor for the right cylinder suspected by the error code. No error found, finally exchanged the ECU under warranty.
My M3W now runs much better at lower rpm's, although few hick-ups occur now in traffic jam with hot engine.
All in all, the new ECU is a big improvement!
Karl
Life is hard in the mountains
2009 silver +4, 2013 red C4P, 2014 yellow M3W gone to a new owner
...drum roll...
Dealer says...bad gas. They emptied the tank, didn't like the look of the gas. Put new gas in and no light. They ran it for a while and the light never came back on.
I had been giving it local, artisanal gas from the gas station nearest to my house. Looks like I'll have to go to a big chain with a name brand instead of the gas station whose name, I believe, is "ATM Inside"
In other news, while waiting for them to come get the M3W, I noticed a clunking coming from the back. I tried to find anything that seemed loose and couldn't. Dealer said he noticed a grinding sound as well. They tracked it down and said there was a bad wheel bearing. Looks like this would have been in the shop this week no matter what. They ordered the part. Hopefully won't take to long. They ordered it from MMC from what I understand though. I would think there'd be something off the shelf closer to home.
By the time I get it back, it will have been in the shop longer than I've had it. Not really upsetting, but it will be if this is a trend. My father wouldn't buy a used Jaguar that I was pushing for in high school because he said that they tend to spend half their time with the mechanic. I remembered him saying that when I did the math on how long this will take to get back.
Nick, the rear wheel bearings are very much a standard bearing so any bearing factor will likely have them in stock or available overnight at worst. I'm not at home just now so can't just quote the spec for the bearings (two identical bearings are required)
Details on previous thread:
http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/258301/Searchpage/2/Main/18214/Words/bearing/Search/true/Re:_rear_bearings#Post258301
Red Leader drive
Thanks. There's good info there. I would assume initial manufacturing defect and not wear, but only because it went at 600 miles. I'll have to check the belt tension.
Got it back last night. Yay! Drove it down the driveway and the check engine light turned on. Booooo!
Drove it back up the driveway to show the dealer before he drove off, and it turned back off. Decided to take it to work this morning and it looks like it is back on.
He had driven it for 40 miles or so after swapping out the gas, and ran it sitting for quite a while too. It never came on for him.
Battery ok? Might need a charge - my M3W seemed to always need a full charge.I used a Tickle charger on it all the time when in my garage.
Neil
