8 members (Strathaven, MartinB60, SteveT, Hamwich, tezzer, Graham, G4FUJ, TeddyAds, BLUE+4), 336 guests, and 86 robots.
Topics49,848
Posts837,399
DazMog, The Impaler, tlchzj79
Hi everyone,
Where might I get the blanking covers that go in the hole in the seat backrest where the headrest "stalk" goes?
Thanks
Hi
You can get blanking plugs from www.mgocspares.co.uk. Part number BHA4985 at £1.55 each including VAT.
I used them on my 2004 4/4 and found them to be the same as those fitted to the old MG's etc.
Regards
Gordon
Rutters sell them, part number TMC097. www.melvyn-rutter.co.uk
Steve L.
1996 Plus 8
N22 MOG
Thank you for the info!
Mind your neck then, whiplash is nasty.
Nigel
Ivo Offline
TM Photographer of 2011
Nigel
I think, with the headrest position, so far away from the head, it makes little difference coffee
sunny
1998 +8 (permanently out of service frown )
Nigel
My '76 has a bench seat - no head restraints.
Cheers,
Graham, I didn't realise that they still had the bench seat in 1976. Do you also have Moseley Float On Air cushions? If so, do you know a source for them other than Little Halingbury?
Greetings Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
South Wales Correspondent
Greetings Frank
Frank,
I have seen replacements from this guy but they were on a rebuilt Austin 7. I don't know if he does them for other marques:
www.bryanpurves.co.uk
regards,
GLLHG
Indeed on the most recent cars the head restraints are rather thin and set far back. When I had new seats made for my '05 4/4 by Shaun at Allon-White, I took his advice and stuck to the (less "fashionable"?) traditional style which are close enough and thick enough to be effective protection. I would feel very vulnerable without head restraints, perhaps because I spend some of my time with spinally injured patients... shocked2
Also I would be surprised if Morgan were legally read able to supply cars with ineffective head restraints - though it is up to you whether you remove them of course!
Nigel
