1 members (Bitsobrits),
304
97
Topics49,860
Posts837,485
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
For some reason I thought these were separate little inserts into the cowl. Aren't they?
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
Interesting that the Morgan full windscreen uses black masking to reduce visibility of the joint next to the cowl.
Tim
Posts: 2,539 |
the worst thing about it is turning it off.
Posts: 1,075 |
Kirk, you've missed one of the most important aspects of the new wheels/ride...
How does Beth like it? Is she a happy camper like you?
Dan
Posts: 1,671 |
Kirk, absolutely fabulous string of posts and photos - welcome into the ranks of M3W ownership and all that entails.
One thing not mentioned that I believe is essential but not designed or even thought about is a hidden rear end tail scuff/skid plate.
The tail of the car is quite some way aft of the centre of the rear wheel, which means that if/when the rear wheel drops either down a kerb or rain gully or ramp the rear will catch or scrape. Ive witnessed this on a number of M3Ws and experienced it myself. It's a simple cure to save the back end and rolled seam at the tail. By the time you realise you need one it's simply too late.
Posts: 2,539 |
How does Beth like it? Is she a happy camper like you? She loves it, but wont drive it!
Posts: 149 |
Mark, where does one source such a rear end skid plate? Do you have a link to a specific part? How about a photo of the plate on your M3W? Thanks so much! Kirk, absolutely fabulous string of posts and photos - welcome into the ranks of M3W ownership and all that entails.
Posts: 1,490 |
Mark was talking about something he'd like that doesn't exist.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 149 |
Thanks....I just re-read Mark's post and now realize that it's something that he would like to see made. I would also like to see a product like this as I have a fairly steep hill to ascend in my neighborhood, along with a few very large and deep speed bumps. I plan to drive slowly and traverse the speed bumps on a diagonal, which should help. Mark was talking about something he'd like that doesn't exist.
Posts: 2,539 |
I cured on noise. This is worth sharing, the front blank number plate screws are so long that they bottom out before the plate is snug. Probably not a problem if you have a number plate up there! i put a couple of washers behind it and fixed!
