1 members (sprinty), 88 guests, and 56 robots.
+8Rich 76
Topics49,863
Posts837,546
Page 61 of 108 1 2 59 60 61 62 63 107 108
Originally Posted By hbatts
I've made a skid plate for my 2012. I made a template of the curve of the body rear and then used 1/8" aluminum plate and made one piece and then made the other. The problem was that the body rear extends about i/8" below the ash frame.The second piece was made to extend past the body to the rear to protect it. I then countersunk four brass wood screws into the ash. I've already had one experience with the skid plate and when the car went over the edge it made quite a "bang". I checked later and all was still intact not loosened and no damage to the body. I was a bit nervous about making four holes into the ash, but everything seems OK. It was a fairly simple project--on a 1-5 level I'd give it a 2
So, now you have even less clearance?😜
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
I will just avoid any ramps or speed jumps, as I've been doing for years with other toys 😉 There is only one route to my house that is hump free. Annoying yes. Restrictive definitely.
On the subject of rears, I've noticed a few M3Ws with stone chips at the lowest point of the bodywork below the number plate frame. In other words, where the back tyre kicks up stones. Has anyone tried to fit a rubber motorcycle 'mudflap' to avoid stones flicking up? It's something easily obtained as a Hog aftermarket part.
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Draggin Offline OP
kirkusblog.com
1952 Ford 8N
That'll do the job, a few screws into the ash frame, job done. It wouldn't be that obvious to see (maybe would need to be cut down a little) and could save a lot of damaged paintwork tears. It's just an idea, need to see how to apply it when mine arrives.
Having owned a number of Caterhams and Lotus, I'm used to having to finish and fettle cars myself. Part of the fun of the ownership. Or so I was told by the dealers.
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Is there really such a thing as a "John A. Prestwich Special"?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Draggin Offline OP
For 68 Grand I say there is!
kirkusblog.com
1952 Ford 8N
Big mud flap works for me every time.
Nicely done
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Morgan's have been littered with Specials almost from 1909 ...so if Kirk wants his to be Special then a Special it is!
For my five penny worth it is every inch a Special!
Neil
Draggin Offline OP
My mom always said I was Special...
kirkusblog.com
1952 Ford 8N
