1 members (yobtaf), 343 guests, and 41 robots.
Topics49,860
Posts837,486
Jonny72
Originally Posted By TimG
Kurt I switch on let fuel pump stop, switch off, repeat twice then start. This was recommended by the Morgan mechanic. Its never a good starter warm or cold day. With engine warm if you switch off at traffic lights you can get caught out with reluctant to start.
Tim
Have you tried the Iridium tip plugs Tim?
Richard no I haven't. Just been serviced with new plugs but dont know what they are.
Tim
Kurt I switch on let fuel pump stop, switch off, repeat twice then start. This was recommended by the Morgan mechanic. Its never a good starter warm or cold day. With engine warm if you switch off at traffic lights you can get caught out with reluctant to start. An optimist on Amazon is offering a pair for £51.
Tim
A pear for £51? Can't be a pair of batteries or Morgan mechanics for that money wink
It could well be to do with the adaptive maps within the ECU software. These continually adjust the fuel mixture and it may have gone right to the border of its parameters to compensate for the cold start. These sometimes need some time to think before a happy medium is achieved again...
Especially with catalytic converters, the engine dumps extra raw fuel to bring the converter up to temp. While it's doing that, engines can run more roughly or stall.
Long idle's will also dump extra moisture into the engine.
For cold starts, just let it idle long enough to smooth out a little (usually 30-120 seconds), then start off at modest rpm's until the oil warms up.
