Morgan Aero 8
8 members (GrumpyPa, Sir Percival, Alistair, TBM, Morganmike, DPEvans, ChrisMorgan, piquet), 294 guests, and 26 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
E
E
The MX5 has been wheel bearing and hub as an assembly since 89. The Subaru and the Suzuki Jeep are still the wheel bearing only.
None of them are adjustable.
To be honest VW and Audi are getting far too clever by half for no apparent gain.
Originally Posted By DaveW
Some modern cars have one option - change the hub and bearing together........................
The Land-Rover Discovery is in this camp. Nearly £400 for a bearing / hub assembly. The worrrying thing was the way it failed. In less than 50 miles it went from a minor rumble to a horrifying screech. Happened on one corner at around 70k miles on the old Disco.
Costock, UK
Disco 5
No they are not adjustable.
They are Gen 1 Wheel bearings as opposed to the Gen 3 hub and bearing fitted to the S2 and beyond Aero so are replaceable at limited expense.
FYI
GEN 0 Wheel Bearing
pair of taper roller bearings, as Trad front stub axles
Gen 1 Wheel Bearing
Large diameter double row Ball bearing
Gen 2 Wheel bearing
Large diameter wheel bearing with Drive flange
Gen 3 Wheel bearing
Large diameter double row ball bearing in carrier, combined with hub assembly
http://www.skf.com/us/products/vehicle-a...kits/index.html
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
