9 members (Soleng, DCH, eds, Ritchie B, DaveW, Luddite, Mike D, TalkMorgan, gazum),
315
33
Topics49,837
Posts837,286
Posts: 2,539 |
Maybe the Urbans no longer need cooling?
Posts: 1,490 |
In Baltimore the Urbans are already cool. The SUBurbans need a cooling kit. The Rurals REALLY need it.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
so far, other than spritzing the front end fasteners with ACF-50, I have done nothing but drive it.
Posts: 128 |
so far, other than spritzing the front end fasteners with ACF-50, I have done nothing but drive it. I've gone around the M3W with a sister product (Corrosion-X). My new best friend. Found some threads that were rusting. Light wire brushing followed by corrosion treatment. Excellent strategy. When I had the M3W up on a lift for the oil change, took the can around and spotted every fastener I could. I think it will have long term benefits--especially in a vehicle with mixed steel & aluminum. Only the owners of Amphicars might benefit more from it.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
so far, other than spritzing the front end fasteners with ACF-50, I have done nothing but drive it. Probably been mentioned before but check for grease throw out onto inner front disc rotor from overpacked bearings, especially as you reach higher speeds  I'm still getting slight splashes from right hand side after 4000 miles, although none ever from the left
Posts: 2,539 |
yes I cleaned some off of the drivers side wheel last night
