4 members (+8Rich, CJB, Winigo, MATTMOG), 248 guests, and 64 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,629
Moggo
madmax Offline OP
Have been taking off the lower brackets fixed to the body to bend them into a v shape so they actually hold the bonnet as they weren't doing due to being flat at the tops. Then front wheels off and spraying a few cans of anti stone chip black stuff to ward off flying grit to avoid dents under ali which would push through to the surface. Bought a 2t hyd jack from screwfix to lift the car as no jack anywhere and obviously no spare wheel ! Looking forward to getting another car lift as have sold my old one , so much easier to look underneath and do jobs ! Wondering about putting a removable plate over the sump plug as it looks just in line with speed humps !
SBM Offline
This any good..?
You've been a busy boy..
madmax Offline OP
This any good..?
Steve thats brilliant , Cain thinks of everything ! I would like to scrap the bonnet stays and get his as these don't have a spring loaded clamp for the stays and if I could find somewhere to put one of his clocks but the airbags are in the way , must be a way ! I see Allon White is a stockist as well as hope to get to their Nov Breakfast meet !
You could probably sell the old bonnet stays on Steve.
Enjoy the fettling!
madmax Offline OP
Enjoy the fettling!
Or fettle them and find a way of having a spring clip at the top end - could do with the top half of Cains set up ! Maybe not ?
SBM Offline
This any good..?
Cain is based just my side of Cambridge so he's within easy reach of a V8...although you may have to fill The Goddess up for the way back, knowing you..
Would be good to see you at Allon Whites, Cain is guest speaker and he has a new project item to talk about.. innocent
madmax Offline OP
This any good..?
Just been reading the 5th Nov breakfast info , looks a must !!
what is the recommended stone chip paint of choice...?
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
madmax Offline OP
James
I used a couple of spray cans of black anti stone chip Hammerite , £6.80 from a local auto accessories shop.
Black Rat
Black Rat
This any good..?
Cain does a matching clock and stop watch mounted on an angled plate that fit to the transmission tunnel.
Keith
2013 narrow bodied + 4 Ruby.
