It would be very heavy I think having had electric power steering fail on mini fiat Punto and Vauxhall etc they are almost impossible to drive.
That's a different phenomenon. Modern front-drive tin-tops with PAS are designed with high positive castor angles to provide steering feel and weight to compensate for the PAS. This also gives improved high-speed stability and better initial turn-in. Without PAS, this geometry will feel VERY heavy.
On a trad Morgan with PAS, I doubt very much whether the kingpin inclination angle has been changed in order to compensate the PAS, consequently much lower levels of assistance are required and other than at parking speed the electronic torque applied to the steering will be minimal.
