0 members (),
230
Topics48,353
Posts813,192
Members9,215
Posts: 2,539 |
Has anyone here in the states gotten an extra set of keys made? Apparently the ignition key is it is a Peugeot and I doubt my local locksmiths going to have blanks for that!
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
I got one cut in the local locksmith,a fairly common profile so you may be lucky. MMC usually have blanks in stock too so you should be able to order one via you dealer. Good luck!
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,539 |
But Taff, you live in Wales. We havent seen A peugot in the states in over 30 years. Maybe I can order blanks online.
Yes more than likely, try fleabay (?). I don't think the key profile is specific to Peugeot so try you local key cutter first. I don't know what Peugeot the switch is off but probably a model current at around 2011. I can send you a pic of my spurious spare if you pm me.
Posts: 7,930 Likes: 218
Posts: 7,930 Likes: 218 |
Has anyone here in the states gotten an extra set of keys made? Apparently the ignition key is it is a Peugeot and I doubt my local locksmiths going to have blanks for that! Didn't you get a spare set of keys and immobiliser fob with car, or is it a third set your after Kirk?
Posts: 2,539 |
its a 3rd set im seeking, I want a full 3rd set to lock away. with the glovebox only lockable by key, my wife is keeping the 2nd set on her all the time, and that makes me uneasy. I guess I could have a glovebox key made and call it a day...
Posts: 360 Likes: 8
Posts: 360 Likes: 8 |
When we replaced our broken key, we recall the guy who cut the replacement saying the blank was for a Saab...might be easier to source than for a Peugeot in the US....
No immobiliser fob on a M3W Richard so it should be easy to source locally for Draggin.
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
No immobiliser fob on a M3W Richard so it should be easy to source locally for Draggin. That depends, if you have the optional immobiliser you need the separate fob as well as the key.
Ah! I thought I had all the options on mine! We live n learn!
