2 members (Simon, Rastus),
332
Posts837,985
Posts: 55 |
My wife and I have secured a spot in the 2017 Great Race. This is a timed-distance rally that will be approx. 2300 miles from Jacksonville, Florida to Traverse City, Michigan next summer over the course of 9 days. There are about 110 cars that have spots next year. I entered our M3W as a back-up vehicle, but we are starting to consider running the M3W as our primary vehicle. We've put about 4,000 miles on the car this summer, with a few minor repairs. The car is a 2013, CENTA upgraded last year. Fixed a bunch of little issues including oil tank leaks, broken rectifier plates, blown tubes, etc. but (knock on wood) she's been running well all summer. Here's a question - what parts would you pack for trip like this? Space isn't limited to the car only - we will be able to have luggage and a little equipment moved with the event team staff. Thoughts? Here is a link to the event if you are not familiar: http://www.greatrace.com/
Posts: 400 |
An inner tube for the fronts, a rectifier and a fuel pump, but that is based on my experiences alone.
Sounds like a lot of fun. Enjoy!
M3W, now!!!
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
and at 3,000 mile service intervals a full service !
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Wow. Sounds like fun.
Jack all tools you can, SAE and Metric. One wrench big enough for the rear wheel bolt! Electrical tape Tubes for front tires. Full oil change w/ filter H-D rectifier Fuel pump Glass cleaner and endless supply of kitchen towels! If you haven't done it then put the front cam-belt cover spacer kit on! No need to keep a spare if that is done. I saw that someone else was carrying a rear belt for a trip to the States. Those are practically indestructible! They are also expensive. Don't
GoPro and mounts! Record this! Have fun!
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Some time ago there was a link on here to a blog from someone that did a Trans America run in a M3W.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,213 |
If you're still on the original rear sprocket/pulley change it for one of the new ones before you set off .
Hugh
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
If you're still on the original rear sprocket/pulley change it for one of the new ones before you set off . +1! The change for the steel version was the greatest improvement and the best noise reduction I experienced on my M3W
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
If you have time its well worth popping across to sleeping bear dunes west of traverse city. 200+ foot high sand dunes are impressive!
Posts: 836 |
Starts in Jacksonville? I wonder where within Jacksonville! The map appears to be made by someone who has never seen Jacksonville before as its located in what is central florida on the map.
Still, would love to come out and watch the send off if I can.
Posts: 2,539 |
Traverse City is not that far from us, Maybe we will go up and witness the cars coming in.
