1 members (Montegue),
297
53
Posts837,277
Posts: 2,361 |
Lawrie, on a side note, the wings look very well mounted.The wings of standard 4/4 look not so well mounted, they look lifted at the outer side. Nothing different, standard wing stays used.
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Another thought, we all know that it is not easy to get fresh cold air to the intake system concerning a Trad Mog, whatever people think about it, it is difficult with the exception of side scoops for single TBs. Regions which are used often are underpressure regions. Concerning coolant radiators, could it be possible to design a radiator with a hole in the lower middle section to let come fresh air through it for the intake filter? (beside the electrical fan).
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Impressive stuff and rewards for hard work.
Richard 1976 4/4 4 Seater
Posts: 2,814 |
I think you need to start building another trophy cabinet! Well done Lawrie, Henry and all of Team Williams.
Gerry
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
I think you need to start building another trophy cabinet! Well done Lawrie, Henry and all of Team Williams. +1
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
I would be interested to read a semi technical description of the car. What has been done to it compared to an ex factory machine, and for what reason?
Well done anyway.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Lawrie,
I think Henry may have something to say about all your trophies being down to "this little beauty".!!!! Well done, you deserve all that for your enthusiasm and hard work.
There is a build thread from last year (earlier?) on the forum.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Lawrie, on a side note, the wings look very well mounted.The wings of standard 4/4 look not so well mounted, they look lifted at the outer side. Heinz...I used to work at a radiator producer. A rad with a gap in it to allow some air through could be done BUT.... It would require a radical redesign. The gap would reduce the area for cooling engine coolant by the rad. Hence either larger rad area or more rows of tubes and different gills format to compensate. Also the flow through the rad would be interupted by the "hole". We used to make some one-off rads for weird and wonderful uses not just auto use.including refurbishing a core block for a Spitfire (plane), but nothing with a"hole". The hole is like putting an obstruction in front of the rad.. A bit like blanking off your rad for winter use to prevent too much cooling.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I think some old classics had a hole through the rad,for the starting handle to reach the crank pulley. Cant remember which cars.
