5 members (+8Rich, deano, Strathaven, Tresco, Socalm3w), 233 guests, and 80 robots.
+8Rich 78
Topics49,871
Posts837,685
Rudolf
Page 4 of 4 1 2 3 4
It's amazing how drilling down the middle of a seized screw or thin shaft allows the outer remaining part to collapse slightly. It often then just twists out with the drill bit itself.
I think the heat or drilling it out also expands then contracts the fastener, also helping things out!
kirkusblog.com
1952 Ford 8N
I have just removed mine to check. There were not difficult to remove, but even so I thought I could feel some rounding of the internal hex by the way the key tended to jam. Maybe they are not high grade material, which would make them easier to drill
Sod's law usually engages itself when removing recalcitrant bolts.
At least it did when I was trying to remove the 3/8 BSP fusible plug from my traction engine boiler a few weeks back.
So, bolt head chewed up (tried Metrinch socket)- drilled out - screw extractor inserted - but turning forces too close to fracturing the extractor (not a good idea) - drilled out up to near pitch diameter - still wouldn't come out - TC dental cutter in Dremel to just on the pitch diameter - finally it came out.
The air was blue!
Tim
Interesting Tim. But I thought that fusible plugs were meant to blow if the boiler overheated. So wasn't heat the way to remove it?
Well no. In an emergency, the lead core in the plug melts and the boiler steam put out the fire if there is a lack of water above the lead. I needed to remove the plug to check it, that being good practice on an annual basis. Local heating with a torch might have helped shift it (would certainly melt the lead) but bear in mind that when running normally the fire itself can be white hot, so probably unlikely to make much difference.
I have now got a BSPT (tapered) plug to put in the re-tapped hole in the spring. The engine is all tucked up for the winter now anyway...
Tim
Tim what is the engine? Long been my dream to own one but likely to stay that way. A photo would be good.
Tim
Here you go Tim.
Taken at the Great Dorset Steam Fair last summer. 4" scale.
Perhaps not quite so many as the Kens, but there do seem to be a few Tims on this forum...
Tim
Page 4 of 4 1 2 3 4
