5 members (bmgermany, Montegue, Ian Wegg, BertL, TBM), 317 guests, and 16 robots.
+8Rich 84
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,361
Page 4 of 20 1 2 3 4 5 6 19 20
Chris99 #405016 04/11/16 05:23 PM
to sexy for pics haha i get some snaps later.
skullmog #405063 04/11/16 07:29 PM
You horrible tease!
skullmog #405075 04/11/16 07:45 PM
i know (really I'm rubbish at getting photos on here, photobucket broken at the mo)
skullmog #405171 05/11/16 11:03 AM
there goin on ,left front on! taking pictures but its only 2 bolts each shock.
Calum the fronts interferance fit with a small week to the top mount as you said.. so far so good .rears look like jack up high to clear fuel tanks. let you know soon as.
skullmog #405172 05/11/16 11:06 AM
Yes...you need to get the car really quite high with the top bolts out of the shocks and the wheel on the deck to get the bottom bolts out.
skullmog #405194 05/11/16 12:34 PM
not able to do rears today,haven't got spanner to fit rear wheel! released top of shocks jacked up but belt holding wheel up,belt interfaces with cross member for the bevel box makes it very tight ,don't want to do any damage in that area.
So it will wait till i bring a spanner home from the garage. Give the fronts test drive tomorrow at blackbushe..... Thanks again for your insights Calum.
skullmog #405247 05/11/16 04:20 PM
Went to halfords got a socket for rear wheel . strip it all out, jack up high, belt loose and out the way, swing arm won't go down far enough to clear fuel tanks......... the bevel box bracket fowls the swing arm ........ either lift tanks /or remove affending bracket... or remove swing arm to let it drop some more.......or put it back together and go out for a ride tomorrow.......Guess who going out tomorrow..........
skullmog #405288 05/11/16 06:23 PM
pic
skullmog #405293 05/11/16 06:36 PM
no clearance
skullmog #405295 05/11/16 06:59 PM
Bugger...I've got one of the slightly odd chassis in that it started as a late 2012, got a 2013 (pre-rubber mounts for bevel box) then got a mid 2015 chassis again without the rubber mounts and associated bracketry for the bevel box. This latest chassis of mine just needs the swing arm pushed gently down with the shock tops unbolted to get the lower bolts out below the tanks.
The settings I have on my Ohlins shocks are;
Fronts 12 clicks back from maximum and 38.8mm pre-load
Rears 14 clicks back from max and 41.6mm pre-load
You can go a fair few clicks either way and still stay within the ball park as each click gives a reasonably subtle change as far as road use is concerned, might be a bit different on a track with a stop watch on the go.
The photos show where I measured the pre-load from (and no, I don't think it is worth measuring it to tenths! I just used a vernier on the calipers as I couldn't find my tape or a ruler in the garage!)
Front
Rear (also shows the offset top hats required for belt clearance)
