10 members (stumog, Fuel.inj, Strathaven, +8Rich, MartinB60, Guten, nestor59310, Graham, G4FUJ, James B W, 2949olivier),
302
Posts837,279
Posts: 400 |
So, JV, you have the Empire kit as well. I love mine. A game changer, if there ever was one. Were the Ohlins as much of an improvement as the Empire kit was? "On top of" the Empire kit, I mean.
Thank you both very much for your comments!
M3W, now!!!
Posts: 462 |
Yes, the Ohlin's may make an even great difference IMHO.
what a pleasure to drive now with just one finger on the steering wheel.
I couldn't take (almost)both hands off the wheel before because of the wild front end movement along with the original bump steering when going over semi big road bumps and railway tracks.
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
What Calum said, so much smoother ride so much more compliant on bad surface roads. foat over speed humps instead of crashing into then over and bumping down otherside. I would describe them as sublime!!!!!!! Chassis so much quieter lost some creeks and groans.....
Just ordered this Sealey one. Not much more and it's a proper combination spanner.  Got a socket for the other side already  Cheers i order mine off amazon, saw snap on man could got one on special £80+vat told him where to put it!!! politely of corse
Got me spanners of amazon less than £20 for 36mm & 24mm....
Well its sunday again, going to have a go at them rear olins again today!got axle stands to keep it all steady.. Hope they as much as an improvement as the fronts.i suspect they will be....
Well thats a faf...the cross member that supports the bevel box has 16mm spanner size nuts n bolts holding it to the chassis,fine who has a 16mm spanner and thin wall socket ? they don't come in a set of spanners or a socket set! I've been in the motor trade 30 years + never used 16mm .good old morgan does like to throw acurve ball in there don't they. Olins all on . Waiting for paint to dry on the already rusty cross member....then test drive
SHORT TEST DRIVE MAKE SURE EVERYTHING TIGHT....the difference is amazing .its like a different car ,loverly!
Calum my tophat offset has to go other way shocks hit fuel tank your way round! clear the belt by about 1.5/2mm .test drive all ok no horrid noises..Thanks for your tips and insights..... Shame they cost so much! every one could have the pleasure of the fantastic ride quality........
Meaning if they where cheaper Morgan would fit them as standard.....
