10 members (asterix, Graham, G4FUJ, Grumpy2, TomS, DJC, Vansrv6, GrumpyPa, BLUE+4, B3MOG, Sir Percival),
308
41
Topics48,364
Posts813,336
Members9,215
Posts: 2,361 |
Thank you for posting. Looks great. Looking forward to future installments. Hopefully daily installments
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
Excellent stuff...many thanks! your welcome
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Superb and like the banjo idea of the brake master cylinder - much better than the pipes close to the clutch fork that I have.
Richard 1976 4/4 4 Seater
Posts: 5,653 Likes: 4
Posts: 5,653 Likes: 4 |
Fascinating to see the build progress. Better fit a temp gauge/alarm to avoid cooking another engine should similar circumstances repeat themselves.
Martin (Deano)
Posts: 2,361 |
Fascinating to see the build progress. Better fit a temp gauge/alarm to avoid cooking another engine should similar circumstances repeat themselves. Already has the gauges installed and working, but didnt pay attention to them, just carried on in the race
Fascinating to see the build progress. Better fit a temp gauge/alarm to avoid cooking another engine should similar circumstances repeat themselves. Already has the gauges installed and working, but didnt pay attention to them, just carried on in the race Expensive mistake to make.
Martin (Deano)
Posts: 909 Likes: 7
Posts: 909 Likes: 7 |
 Very interesting. Thanks Stefan 4/4 Arp4 +8
Posts: 2,361 |
So today I finished off making up the last braided brake line for the new brake master cyclinder. The system was then fully bled and number of times.   As the new engine is dry sumped, I now no longer need the old horrible looking oil catch tank which was poorly attached to the N/S bulkhead. The new oil tank comes with a breather tank attached.  I then made a carboard template for the 3mm sheet metal im going to use to over lay this part of bulk for strength. This is where the oil lines and fuel lines will come through using the correct bulk head connections. The original bulk head metal work will be neatened up and filled before the new sheet goes over the top.  Doesn't it look glamerous lol I then turned my attention to the new fuel system seeing as I had a big order delivered. Cant beat free next day delivery!! Post pump fuel filter  The new Bosch Motorsport fuel pump. Yes the pump mounting bracket needs to be secured properly.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Posts: 1,415 |
Fascinating to see the build progress. Better fit a temp gauge/alarm to avoid cooking another engine should similar circumstances repeat themselves. Already has the gauges installed and working, but didnt pay attention to them, just carried on in the race I used to have a driver like that... I threatened to wire the HT circuit through one of the warning lights and into the crotch strap on his harness. Strangely enough he started being much more observant after that... Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
