10 members (Strathaven, Liam1961, Alistair, bmgermany, ScottMellor, JMcL, Mick Annick, RedThree, TeddyAds, Saxman1964),
197
51
Topics49,888
Posts837,886
Posts: 1,036 |
One modification you can consider when using a 45 or similar non 90 degree pipe is to cut the pipe exit so that it aligns with the edge of the wing.
Better to allow a little extra as it should ensure that the gasses exit away from rather than under the car.
Posts: 228 |
Thanks for all the responses.
Having looked at the car it seems there probably isn't sufficient space. The position of the rear support bracket means there is very little space between it and the rear of the wing/wheel arch, certainly not enough to accommodate the bend and the pipe. I suspect the silencer is shorter on the 1.6 4/4, and the bracket further forward. Perhaps it's a quirk of the 2.0 duratec 4/4?
So, unless I alter the bracket position, which I doubt I'll try and do, then I'll probably need to forget the idea.
Thanks again.
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Thanks again. Or maybe play around and adapt a cheapy shorter silencer.
Roger 2011 Plus 4
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
The side exit exhaust on my 4/4 is actually part of the handle of an industrial vacuum cleaner. Fitted as a stop gap about 7 years ago, looks the part, does the job and cost nothing!
Arwyn
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Arwyn Doesn't that make your back ache doing the stairs..?
Dunno, found it in the scrap skip at work!
Arwyn
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
The side exit exhaust on my 4/4 is actually part of the handle of an industrial vacuum cleaner...
Arwyn Doesn't that make your back ache doing the stairs..? I was wondering how long the mains lead would need to be??
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Dunno, found it in the scrap skip at work! Arwyn And they say we're tight!
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Pick the wrong hoover and you could be Dyson with death.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Dunno, found it in the scrap skip at work! Arwyn And they say we're tight! Difficult to convert a broom handle into a side exit exhaust
