1 members (GrumpyPa),
260
64
Topics49,888
Posts837,884
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Dunno, found it in the scrap skip at work! Arwyn And they say we're tight! Difficult to convert a broom handle into a side exit exhaust ?
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Dunno, found it in the scrap skip at work! Arwyn And they say we're tight! Difficult to convert a broom handle into a side exit exhaust ? Why would a scot buy a Hoover when a broom will do. No hole in a broom handle. Sorry for the type casting but you started it
Why would a scot buy a Hoover when a broom will do. No hole in a broom handle. Sorry for the type casting but you started it I take it you mean Scot? No offence taken. My broom is still original.
Why would a scot buy a Hoover when a broom will do. No hole in a broom handle. Sorry for the type casting but you started it I take it you mean Scot? No offence taken. My broom is still original. Yes sincere apologies, Scot is what I meant. Glad your broom is still original, so is mine although I did have to fit a new head and handle this year.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Im off down the pub.
Yes sincere apologies, Scot is what I meant. Glad your broom is still original, so is mine although I did have to fit a new head and handle this year. Only one new head and handle?
Yes sincere apologies, Scot is what I meant. Glad your broom is still original, so is mine although I did have to fit a new head and handle this year. Only one new head and handle? Yes I'm trying to preserve the authenticity
Posts: 228 |
......and back to the original topic  I've now done a little more research and it seems I may be able to buy a nice tight 90* bend (52mm radius) and add tube either side, one with a socket. I'd just need a few careful measurements and perhaps extend the extend the centre box supporting bracket.  Cost of the bits is probably about £40 delivered. So, my next questions are how easy would it be to have the stainless tube butt welded? Is this a specialist task or can most exhaust fitters normally do it? Is likely to be expensive? Cheers
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Its relatively easy to weld stainless as long as you gave the correct gear - TIG welder, correct shielding gas and the correct filler rod.
Don't think an exhaust fitter would have that sort of gear.
My local coded welder charges me 10 quid for doing exhaust pipe welds as long as I prepare the job for him - I.e parts off the car, the joint cleaned to bare metal and bevelled and clear instructions to him
Hope this helps
Arwyn
Posts: 228 |
Andy
