3 members (JMcL, Saxman1964, PaulV), 129 guests, and 67 robots.
+8Rich 74
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Topics49,888
Posts837,886
Page 2 of 4 1 2 3 4
One modification you can consider when using a 45 or similar non 90 degree pipe is to cut the pipe exit so that it aligns with the edge of the wing.
Better to allow a little extra as it should ensure that the gasses exit away from rather than under the car.
AndyR Offline OP
Thanks for all the responses.
Having looked at the car it seems there probably isn't sufficient space. The position of the rear support bracket means there is very little space between it and the rear of the wing/wheel arch, certainly not enough to accommodate the bend and the pipe. I suspect the silencer is shorter on the 1.6 4/4, and the bracket further forward. Perhaps it's a quirk of the 2.0 duratec 4/4?
So, unless I alter the bracket position, which I doubt I'll try and do, then I'll probably need to forget the idea.
Thanks again.
Andy
2011, 4/4, 2.0, 75th Anniversary
2016, VW Polo GTI
2012, BMW 520d Touring
Rog Offline
Thanks again.
Or maybe play around and adapt a cheapy shorter silencer.
Roger
The side exit exhaust on my 4/4 is actually part of the handle of an industrial vacuum cleaner. Fitted as a stop gap about 7 years ago, looks the part, does the job and cost nothing!
Arwyn
SBM Offline
Arwyn
Doesn't that make your back ache doing the stairs..?
Dunno, found it in the scrap skip at work!
Arwyn
The side exit exhaust on my 4/4 is actually part of the handle of an industrial vacuum cleaner...
Arwyn
I was wondering how long the mains lead would need to be?? grin2
Arwyn
And they say we're tight!
Best Regards
Lang may yer lum reek
Pick the wrong hoover and you could be Dyson with death.
nono
Black Rat
Black Rat
Arwyn
Difficult to convert a broom handle into a side exit exhaust hide
Keith
2013 narrow bodied + 4 Ruby.
Page 2 of 4 1 2 3 4
