5 members (piquet, GrumpyPa, JMcL, DavidR, vincentvg), 296 guests, and 45 robots.
Luddite 50
Posts837,951
Page 4 of 4 1 2 3 4
--and a change of underwear?
There are sprayers for cleaning leaves out of house gutters that have sort of a shepherd's crook with a small sprayer at 90 degrees.Could probably lay it flat on the ground, sprayer pointing up, to remove under-carriage debris.
Hey i have one of those!
kirkusblog.com
1952 Ford 8N
Originally Posted By DaveW
Originally Posted By +8Rich
It's no wonder there are so few entrants Dave - that is crazy checking tyre treads for excrement.
And stones. And if you are really serious the tyre markings must align with the valve on every wheel, and all the valves and centre caps must line up.
BUT we don't do that in the MSCC. We make it informal and we still don't get support.
I took a classic car to an all makes rally in Aberdeen. They expected you to empty the boot & remove all your stuff from inside the car to be judged. I told them I would not bother.
If you use much more than mains pressure expect water inside the car. I have an under body wand for my pressure washer with 60deg upturn & swivelling fan nozzle for cleaning under wheel arches. I do not use it on my M3W.
Tim
Ray Offline
Emptying the boot on a trad is no problem. hide
I got a telling off once for leaving a yellow duster in the glove box.
Page 4 of 4 1 2 3 4
