8 members (Steve +8, +8Rich, jbk, Joske Vermeule, mph, Mogdavid, Sir Percival, Alan Patterson),
240
53
Posts837,957
Posts: 582 |
--and a change of underwear?
Posts: 128 |
There are sprayers for cleaning leaves out of house gutters that have sort of a shepherd's crook with a small sprayer at 90 degrees.Could probably lay it flat on the ground, sprayer pointing up, to remove under-carriage debris.
Posts: 2,539 |
Posts: 1,947 |
It's no wonder there are so few entrants Dave - that is crazy checking tyre treads for excrement. And stones. And if you are really serious the tyre markings must align with the valve on every wheel, and all the valves and centre caps must line up. BUT we don't do that in the MSCC. We make it informal and we still don't get support. I took a classic car to an all makes rally in Aberdeen. They expected you to empty the boot & remove all your stuff from inside the car to be judged. I told them I would not bother.
Posts: 1,947 |
There are sprayers for cleaning leaves out of house gutters that have sort of a shepherd's crook with a small sprayer at 90 degrees.Could probably lay it flat on the ground, sprayer pointing up, to remove under-carriage debris. If you use much more than mains pressure expect water inside the car. I have an under body wand for my pressure washer with 60deg upturn & swivelling fan nozzle for cleaning under wheel arches. I do not use it on my M3W. Tim
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
It's no wonder there are so few entrants Dave - that is crazy checking tyre treads for excrement. And stones. And if you are really serious the tyre markings must align with the valve on every wheel, and all the valves and centre caps must line up. BUT we don't do that in the MSCC. We make it informal and we still don't get support. I took a classic car to an all makes rally in Aberdeen. They expected you to empty the boot & remove all your stuff from inside the car to be judged. I told them I would not bother. Emptying the boot on a trad is no problem.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
I got a telling off once for leaving a yellow duster in the glove box.
