With respect to the governmental agency that required the big bold red label on the engine cooling duct on my new M3W that makes a retro vehicle looking very not retro, I was wondering if anyone has attempted to remove that epithet?
If appears to be painted on and if that is the case - is their an aftermarket cooling kit that has a little less obtrusive appearance on the engine?
I will try to peel off the "DANGER HOT!" label. It might come off more easily after the engine warms it up. I am a little afraid to try "Goof Off" as it might remove the paint along with it.
Does anyone know of an aftermarket cooling kit with a less obtrusive cooling fan shroud over the engine? I enjoy the look of the earlier M3W's with the fully exposed engine.
Definitely don't use goof off on painted surfaces! That's just vinyl lettering WD-40 is sufficient for removal. Might take a bit of time, but it'll leave the finish totally clean. Using goof off you might as well prep for a sanding and repaint.
When we was at Blehiem a small person asked his dad "what's F ING HOT mean" like a shot dad say's flipping hot son. Fantastic translation i said to him, thumbs up was the reply.....
The Danger Hot is only a sticker or transfer and should come off fairly easily. Melvyn Rutter does a polished stainless steel heat shield which fits over the existing but is slightly smaller and therefore requires some trimming of the plastic. I have one but my only criticism is that the polished stainless has a slightly different hue to the polished alloy of the engine. The awful plastic original shields are painted by the Factory prior to fitting.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Here's the stainless cowl cover which fits over the top of the Morgan plastic cowl. IMHO it's a better look than the factory washing machine ducted fan version but is still no where near as good looking as the original un-ducted 2012 M3W.
I've also fitted a 'Super Sports' stainless cowl badge to the stainless cowl too.
I found that the factory scoop chaffed the standard rocker covers but with the confederate finned covers fitted there's additional clearance so no more rubbing!
