0 members (), 325 guests, and 38 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#41745 18/03/10 12:43 PM
I recently had an MOT on the +8 and have to replace a torn wiper blade. They are 165mm long. Do they fit anything else other than Morgans does anyone know?
I think VW Beetles
John V6 #41749 18/03/10 01:42 PM
Quote the length to an auto factors and they will be able to select one off the shelf.. the packaging has the length on the boxes as well as the part number.
Thanks for the replies. Thought they might be too small for an auto factor but will give it a go. cheers
Heart of England Morgans / John Worrall...
Cheers,
Bought from Halfords & cut length to suit! innocent
New joints for old!
orthodoc #41800 20/03/10 12:44 PM
Went to Halfords but nothing short enough or of the same type. What size did you buy and what was it listed as being suitable for please. Also how did you get the blade into the holder. I cant see how to open and re-crimp it. Many thanks sos
Ask a dealer? Ring the factory?
Also Heart of England Morgans or Melvyn Rutter will almost certainly have stock or know where to get them.
I think they are the same as older Landrovers...?
nputtick #41803 20/03/10 04:00 PM
Try Go Mog for advice viz:-
WIPER BLADE REPLACEMENT
For those of us with a difficult access to a Morgan Agent, you will find the the early Volkswagon Beetle wiper blades work fine with a Morgan. By the way, for the purists, there are two sizes of Morgan wiper blades (regular and four-seater windscreen which is a tiny bit longer.
You can also simply replace the rubber only. Use silicone to glue-in new rubber for the wiper blades. Two dollars gets you new refills for modern wipers- long enough to do three-four Mog blades. The new blades let the rubber do the flopping rather than the whole blade.. and they work a LOT better than original. (keep the new glass clean..).
http://www.gomog.com/allmorgan/screens.htm
