Topics49,900
Posts838,039
Posts: 25 |
I recently had an MOT on the +8 and have to replace a torn wiper blade. They are 165mm long. Do they fit anything else other than Morgans does anyone know?
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Posts: 2,568 Likes: 98
Posts: 2,568 Likes: 98 |
Quote the length to an auto factors and they will be able to select one off the shelf.. the packaging has the length on the boxes as well as the part number.
Posts: 25 |
Thanks for the replies. Thought they might be too small for an auto factor but will give it a go.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Heart of England Morgans / John Worrall...
Cheers,
Posts: 561 |
Bought from Halfords & cut length to suit!
New joints for old!
Posts: 25 |
Went to Halfords but nothing short enough or of the same type. What size did you buy and what was it listed as being suitable for please. Also how did you get the blade into the holder. I cant see how to open and re-crimp it. Many thanks
Posts: 1,502 |
Ask a dealer? Ring the factory?
Also Heart of England Morgans or Melvyn Rutter will almost certainly have stock or know where to get them.
I think they are the same as older Landrovers...?
Try Go Mog for advice viz:- WIPER BLADE REPLACEMENT For those of us with a difficult access to a Morgan Agent, you will find the the early Volkswagon Beetle wiper blades work fine with a Morgan. By the way, for the purists, there are two sizes of Morgan wiper blades (regular and four-seater windscreen which is a tiny bit longer. You can also simply replace the rubber only. Use silicone to glue-in new rubber for the wiper blades. Two dollars gets you new refills for modern wipers- long enough to do three-four Mog blades. The new blades let the rubber do the flopping rather than the whole blade.. and they work a LOT better than original. (keep the new glass clean..). http://www.gomog.com/allmorgan/screens.htm
