3 members (DavidR, +8Rich, John Winn), 269 guests, and 28 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
Page 2 of 4 1 2 3 4
Hi,
The spot lamps/driving lamps on my ARP4 operate on an independent switch and stay on when the main beams are dipped. This makes them unusable in my view except on very quiet roads late at night when you are not constantly changing light settings.
I am considering wiring them to the main light dip/full beam switch as suggested, or seeing if I can change the alignment such that they provide some useful light without dazzling other road users. A doubt the latter will be feasible but at the moment mine are aligned skywards and slightly bosseyed and serve mainly to burn the retinas of approaching drivers!
Regarding the ignition switch I have the same concern. In practice it's not been an issue, but sooner or later someone will accidentally switch their ignition off while driving I am sure.
I have considered fitting a 'helicopter switch' to the ignition to make it more obvious - same as those fitted to many Caterhams. These are in fact designed to allow the ignition to be switched off very quickly e.g. by marshals following a race car crash. As a more appropriate alternative, I will most likely fit a locking toggle switch when I find a suitable one - the type that requires you to pull the switch outwards and past a detent to change setting. I will post a picture if I can find one
Regards
Ferrari 488 Pista
Porsche 991.2 GT3
Porsche 718 Spyder
Caterham 620R
BMW M2
Porsche Macan Turbo
Originally Posted By John V6
you were lucky they had any lights on. Near Amersham a great many didn't.
There were a few like that yesterday up on the Cotswolds. Why is usually the dark coloured cars that are the worst offenders?
I think you can replace all the toggle switches with self illuminated versions, company's like car builder solutions can supply them
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
As a generality they were all black Graham. Stealth mode I guess.
Black Rat
Black Rat
Originally Posted By Marchogion
In the days when an extract from the Construction & Use Regulations was printed in the back of the Highway Code it said that lamps mounted less than 2 feet from the ground could only be used in fog or falling snow. I believe this was later changed to significantly reduced visibility. I know someone who was prosecuted some 10 years ago for using fog lamps in normal conditions. The current regulation states that front or rear fog lights must not be used unless visibility is seriously reduced (generally when you cannot see more than 100 metres). However the recent proliferation of cars driven around with fog lamps on would suggest that plod is turning a blind (dazzled?) eye.
This is still true except it is probably not that "Plod" are ignoring it, it's that there are not enough of them to deal with the problem like many other offences thanks to Teresa May oldgit
Keith
2013 narrow bodied + 4 Ruby.
John, We counted thirty vehicles, the other night, in the space of 40 kilometers, with either only one functioning headlamp, or sidelights only and sometimes only one and two with lights so dim as to be almost invisible and that was just the ones approaching us.
Anyone remember the Rover 2000 and 3500 with shaped switches so that they were instantly recognizable?
Out of curiosity, is there a dimmer for the dash illumination on an ARP4?
If so it might be simply turning it as it may be on dark setting?
Have you not seen Paul J's thread about just such a dimmer?
Tucked into the wiring loom (before he mounted it to a panel).
Thanks Graham. I hadn't but I have now!
AR P4 Kingfisher Blue - Morag
Formerly 2007 Plus 4 - Molly
Worcestershire
smile smile
Actually a comment to Phil, as he was asking about dimmer, but hope it might help you too Biffo! thumbs
Happy New Year smile
Page 2 of 4 1 2 3 4
