5 members (CRL, IcePack, Bunny, Ian Wegg, MartinB60), 310 guests, and 111 robots.
+8Rich 77
Topics49,868
Posts837,642
Moggo
Page 80 of 108 1 2 78 79 80 81 82 107 108
Draggin Offline OP
There has been a lot of speculation about the waterproof leather option, below is a link to the company that makes it. There was also speculation about it being plastic, let me assure you it is not if anything it has more of a slightly waxy feel to it. It seems to be very high quality stuff.
http://www.xtreme-collection.com/en/xtreme-leder/
kirkusblog.com
1952 Ford 8N
Very clever technology.
Good find ...thanks for that ...most interesting!
Neil
Draggin Offline OP
I guess if there are just 2 i would drill them both...
The trick I doing it so "She Who must be..." does not know i did it!
She is very anti me messing with the car.
It does only have 350 miles on it!
kirkusblog.com
1952 Ford 8N
The rear baffle already has holes in it. I took it out with a hole saw first, beacuse it was easy to reach. Much nicer exhaust sound and a marked improvement on pinking.
The front one demands two extensions on the drill (= one more) and then it all starts to wobble. Approach from the front. It has no holes in it at all, the fumes go "around" it, so to speak.
As a precaution against too much noise I have drilled four 9 mm holes in the front baffle and I am still evaluating. More, throatier exhaust rumble and the manifolds no longer glow red. Almost no pinking.
Not sure I need to use the hole saw and there is room for at least four more 9 mm holes.
Oh, a tip for you: It takes forever to get the bit to bite into the stainless, but using an impact drill made it a doddle. It took seconds to drill a hole, in stead of several minutes.
M3W, now!!!
Impact drill is a good idea, never thought of it. I sharpened the end of a long rod and center punched the front one first and then the hole saw didn't wobble.
Draggin Offline OP
The state of the pound and possible tarrifs has me thinking about what should i buy now from England. As it will likely never be cheaper.
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
some photos...
kirkusblog.com
1952 Ford 8N
JVS Offline
Sweet!
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
JVS #423393 19/01/17 08:36 PM
thumbs thumbs thumbs
Red Leader drive
Draggin Offline OP
couple more...
kirkusblog.com
1952 Ford 8N
