Topics49,859
Posts837,478
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
They were bottom of our options list and we decided to do without. (Four wheeler).
ZK-Mog Talk Morgan Regular
Posts: 584 |
I have them. I've never used them except by accident and wondered why my bum was burning. It never gets cold enough where I live and I find the engine keeps the whole cockpit area warm anyway. A heated steering wheel would be a better option.
There is some smug satisfaction in explaining to people that the 2 buttons are for heated seats but you can easily live without them
Posts: 213 |
I use my heated seats often up here. If it gets too hot, I move the switch to the off position. I also have an electric vest and electric gloves for motorcycle use. The worst cold I have ever experienced was before dawn on a July morning in Wisconsin on the motorcycle, before I left home I thought "This is July, I shouldn't need the vest or gloves" Never again. And I have seen a lot of -20F, and colder. Even in 45F ambient, the wind chill at 70mph is hellaceous.
Inge
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
I ordered them. Inexpensive option. Nice convenience for cold rides. My wife covers up with her Morgan blanket and appreciates the heated seats.
Posts: 149 |
I have them and have used them every time I have taken my new M3W out for a ride....it should be noted that I took delivery of my car on December 23rd, and I live in Connecticut! All cold weather rides thus far!
The heated seats do get rather warm....almost on the verge of being "hot". I have to switch them off after a while, and toggle them on and off on longer rides in cold weather.
For the relatively low cost of the option, I recommend them.
Posts: 1,490 |
For the relatively low cost of the option, I recommend them. I concur. I'd prefer they have multiple settings. If just one if should be less hot.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
I agree, they do get abit too warm after awhile, then turn them off. Two or three settings a good idea. Perhaps the designer figured heat up fast then turn off and your own body heat will keep the seat warm.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Could a variable resistor not be added to control the temperature?
Richard 1976 4/4 4 Seater
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Could a variable resistor not be added to control the temperature? It could, but that would heat up instead. What you really want is a timer option (turns off after 5mins, or turns on and off at certain intervals to regulate heat output). Or maybe even a thermostat?
Posts: 306 |
Could a variable resistor not be added to control the temperature? I was thinking the same thing. On my volvo it had three levels. I'd be curious about replacing the little toggles with some rheostats.
