3 members (+8Rich, JohnHarris, bmgermany), 255 guests, and 36 robots.
+8Rich 95
John V6 52
Posts838,003
rockabilly john
#424541 24/01/17 11:50 AM
Checked the fuses on my 2000 reg Zetec 4/4 and still can't get my hazards to work. Is there a separate flasher unit for them, if so, where to look? confused2 crazy2 frown2
Gerry
Looking at this circuit diagram there appears to be two under the dash associated with the hazard lights. The low brake fluid warning relay appears to be the same on the drawing so you maybe could swap it over in the absence of a spare, the wiring colours should identify the relays once you are in there amongst it.
There is a multiway connecter in there too ? Another one associated with the hazard switch ?
www.gomog.com/allmorgan/4~4%20Diagram%20for%20Morgan%20Dash%201800%20Focus.pdf
Lifted off the gomog site 1998 - 2004 4/4.
Good luck.
Had the same problem, found the inline fuse blown, fuse was hidden between the battery and rear bulkhead behind the passenger seat.
Not sure if you have the same layout.
Dave
98 +8 Corsa Red
74 MGB Red
Dave do you have any pictures of lowering plus 8 bumpers
Allan 2005 Roadster
