7 members (Chris Cosher, Scrambledsignals, DavidR, Sir Percival, sewin, John V6, Joske Vermeule),
284
Posts837,995
Posts: 2,814 |
Gerry
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Looking at this circuit diagram there appears to be two under the dash associated with the hazard lights. The low brake fluid warning relay appears to be the same on the drawing so you maybe could swap it over in the absence of a spare, the wiring colours should identify the relays once you are in there amongst it. There is a multiway connecter in there too ? Another one associated with the hazard switch ?
www.gomog.com/allmorgan/4~4%20Diagram%20for%20Morgan%20Dash%201800%20Focus.pdf
Lifted off the gomog site 1998 - 2004 4/4.
Good luck.
Posts: 463 |
Had the same problem, found the inline fuse blown, fuse was hidden between the battery and rear bulkhead behind the passenger seat. Not sure if you have the same layout.
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 23 |
Dave do you have any pictures of lowering plus 8 bumpers
Allan 2005 Roadster
