Morgan Aero 8
5 members (Ubiquitous, GrumpyPa, PaulG, MJF, Adam12), 279 guests, and 38 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,325
Members9,215
Page 4 of 5 1 2 3 4 5
asbojohn #42593 05/04/10 04:20 PM
Thanks John, that seems like a good idea. The only potential flaw is that the garage is underground and they say "when exposed to daylight, even through glass and on cloudy days."
I take your point on calculators working with electric lights, but does anyone know if this Charger will a) work indoors from an electric light source and b) will it be safe to leave connected as it is not a battery conditioner?
Cheers
Brian
Brian
2014 Morgan SP1 (Rocket Red)
Aeroman #42595 05/04/10 04:48 PM
le Asbo du Bling
le Asbo du Bling
Brian
I think chargers offer a bigger boost than these sorts of things.
This one is described as a trickle charger which is what I assume the conditioner is doing most of the time.
Trickle Charger
If I understand the technology behind these correctly they should work with all light sources although the output may vary. The ideal way to measure it would be to leave the aero and check the power in the battery and then monitor it a week later to see how much has disappeared. If you can disconnect the battery and then leave one of these attached for a week you will be able to see if its made up the shortfall.
If its topped it up to half the original level then simple maths would suggest doubling the panels surface area.
As I've said before it would be far easier if you let me look after it for you. thumbs
Bedtime reading
Solar Cells
Slowly going green
asbojohn #42637 06/04/10 04:09 PM
Smile, it confuses them
Then of course once you have calculated how large you need you can go totally over the top and get something REALLY big from Maplin.
http://www.maplin.co.uk/Search.aspx?criteria=solar%20panel&source=15
Just don't go licking the terminals like I did stars
Old habits die hard and I was once a bench engineer for a PC company, but i'm all better now.
Alistair #42658 07/04/10 05:51 AM
LOL,
Apparently 3 people per year die from testing the 9V PP3 battery with their tongues! scared
Still a bench engineer for an IT company, who wishes he'd never left radio...
Cheers,
'09 Gen2 MINI Cooper ragtop
le Asbo du Bling
le Asbo du Bling
Cheers,
Graham Brilliant if true, out of interest do you have a source for this, or is it another urban myth?
Note to self stop testing batteries with tongue. tongue2
Slowly going green
asbojohn #42663 07/04/10 07:37 AM
It was a number of years ago John.
A report on accidents in the home on something like Radio 4.
The general public may have taken heed by now and found another way to kill themsleves, errr, test batteries wink.
A quick Google brought the following up as the first result:
http://www.theregister.co.uk/2006/07/28/the_odd_body_death_by_battery/
So, it seems unlikely, but not impossible.
Cheers,
le Asbo du Bling
le Asbo du Bling
Graham,
This is the bit that caught my eye
Asked by Liam Johnson of Frankfurt, Germany
"Here's Liam's question in full:
First the simple question: Can you die from testing a 9V battery on your tongue? I have read newspaper reports (around 1990) of a woman dying after her boyfriend used a 9V battery as sexual stimulation."
This now raises the following question. Can a trickle charger be used as a form of electrical viagra? read
Slowly going green
asbojohn #42677 07/04/10 03:40 PM
Originally Posted By asbojohn
Can a tickle charger be used as a form of electrical viagra?
Blimey Asbo, what have you been up to? shocked2
grin2
Brian
Aeroman #42678 07/04/10 03:44 PM
He's been playing with his TENS unit again
The mind boggles...
Brian
