5 members (linklaw, tezzer, Pittsartist, Alistair, Robbie), 285 guests, and 76 robots.
+8Rich 86
Sagging Hood
Topics49,853
Posts837,447
#426750 02/02/17 07:07 PM
Rog Offline OP
I removed my plastic throttle body a few days ago to re-seal the butterfly plate as I have been chasing a long standing air leak/idle issue. Whilst it was removed I noticed that my TB had been restricted. The butterfly plate was restrained from fully opening to the normal 90 degrees. By design it had been limited to around 70 degs . Curious as to what was going on I did a little investigation and found that this appears to be the case on the 1.8 engines only. On the 2 litre Duratec the butterfly plate opens fully. These two engines are virtually identical and even use the same plastic TB moulding. The subtle difference is the little metal bracket on the side of the TB assembly that the throttle cable attaches to. On my car the bracket restricts the movement.
Why did Ford chose to do did this I wonder? Was it to ensure a meaningful difference between two similar products? hide Whatever the reason it presented the tantalising prospect as to how the engine might perform if the restriction was removed? Fortunately I had a second hand 1.8 TB that I had previously picked up just in case I couldn’t seal the air leak in my original. Curiosity got the better of me and just had to go get the saw.
Here’s the original 1.8 TB
Bracket modified to match the 2 litre. I wouldn’t recommend anybody doing this. It would have been so much easier to just to have picked up a 2 litre TB in the first place.
Here’s the difference with butterfly fully open - before and after.
Today I put it back on the car, re-adjusted the cable and out for a quick of blast. Early days yet but all working very well indeed. woohoo I was anticipating disappointment thinking that the engine would “bog” when the throttle was fully open owning to insufficient fuel but not so at all. This may be attributed to having a performance remap installed recently and that may be adding a little extra fuel anyway. Whether the standard 1.8 calibration would perform the same I can’t say.
This mod might be here to stay smile
Roger
Black Rat
Black Rat
Well spotted and dealt with happy3
Keith
2013 narrow bodied + 4 Ruby.
That has to the best value ever in speed equipment.
regards,
Phil
Brilliant
Nick
Good job thanks for posting it.
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
Thanks Roger , going to try on our 4/4 1.8 (blacktop ).
Who did the remap , and is it good ?
Stefan
Rog Offline OP
Stefan
Hi Stefan
I bought a master file directly from Viezu . As I had the kit to re-flash my own ECU there was little point in going to a dealer. I believe a dealer might use a tuning company like Viezu if you purchase a re-map through them.
Don’t expect too much from a remap on the 1.8! My first impression after jumping in and driving around the block was that it seemed very slightly more tolerant (happier) at pulling at low engine speed in the lower gears. Which I have to confess is more relevant for my driving style and I am happy with that. It’s difficult for me to compare any power differences because it only really becomes apparent up towards the top end which to be honest is not how I drive. Having said that it does seem a bit more frantic up there. The remap hasn’t been in that long and over the winter my car hasn’t been very far at all, just a few very local trips. I’m looking forward to the opportunity for a decent run to really try it out.
PS – This ECU comes with the same tune if required smile
Roger
The 1.8 responds very well to a little tuning, sports exhaust etc. Just try chasing a good one in a standard 2.0 Plus 4 and you will find that they do not lack performance.
Thanks for the info
stefan
Rog Offline OP
Images from this post re-posted owing to the photobucket debacle.
Roger
