Posts837,965
Posts: 986 |
Think I know the answer to this but does anyone know if an inoperable windscreen washer is an MOT failure? My Mini I would add not the Morgan.
Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Copied from MOT site.. Short answer is yes they must work.
Requirements Operate to give the driver a clear view of the road
Wipers and washers
The inspector will pay close attention to the operation position and function of your wind screen wipers and washers.
Washers will be required to work in order to pass the mot test. Even running out of water in your screen wash bottle is enough to cause an MOT failure.
Wiper blades must be in good condition and be of the correct size for the vehicle they are fitted to. They must provide the correct range of wipe to allow the driver to have an un-obscured view of the road ahead.
Common faults
Torn wiper blades: will result in an MOT failure. This can be diagnosed by visually checking the condition of the blades. If any tears are discovered it will make sense to replace them before submitting your vehicle for it's MOT. Blocked washer jets: Are grounds for an MOT failure Common reasons for blockages are washer bottle contamination and wax blockages. In most cases the jet can be cleared using a sewing needle. Take care when doing this to avoid injury.
Posts: 148 |
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6 Audi A4 Advant (some blue colour not botherd)
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Unless you go to the garage with aero screens on .
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I think it is also illegal to drive with empty washer bottles.
Posts: 986 |
Thanks everyone, I'll have to raid the sewing box to find a needle!
Andy
Posts: 3,701 Likes: 133
Posts: 3,701 Likes: 133 |
Unless you go to the garage with aero screens on . That's a valid point. I once got a series II Land Rover through the MOT with a failed wiper motor by folding the windscreen flat. Not an option on a Mini I'll grant you. ~iw
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I think it is also illegal to drive with empty washer bottles. Actually if it's raining it could lead to a prohibition notice !!!
Andy Best to not use a needle as its tapered and often too big, the best thing to use is a single strand out of a wire brush.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Check the bottle and filter for pond life. It's surprising what grows in washer fluid.
