8 members (Montegue, TalkMorgan, tezzer, Graham, G4FUJ, RichardV6, CooperMan, JohnHarris, Haggispeed), 349 guests, and 20 robots.
+8Rich 91
John V6 49
Posts837,983
#431057 20/02/17 10:10 PM
Think I know the answer to this but does anyone know if an inoperable windscreen washer is an MOT failure? My Mini I would add not the Morgan.
Andy
Laser red 4/4
Red Classic Mini Cooper Sport
Audi TT 2.0 TFSI Quatro
Brum Rum #431062 20/02/17 10:23 PM
Copied from MOT site.. Short answer is yes they must work.
Requirements
Operate to give the driver a clear view of the road
Wipers and washers
The inspector will pay close attention to the operation position and function of your wind screen wipers and washers.
Washers will be required to work in order to pass the mot test. Even running out of water in your screen wash bottle is enough to cause an MOT failure.
Wiper blades must be in good condition and be of the correct size for the vehicle they are fitted to. They must provide the correct range of wipe to allow the driver to have an un-obscured view of the road ahead.
Common faults
Torn wiper blades: will result in an MOT failure. This can be diagnosed by visually checking the condition of the blades. If any tears are discovered it will make sense to replace them before submitting your vehicle for it's MOT.
Blocked washer jets: Are grounds for an MOT failure Common reasons for blockages are washer bottle contamination and wax blockages. In most cases the jet can be cleared using a sewing needle. Take care when doing this to avoid injury.
Brum Rum #431072 20/02/17 10:55 PM
Yes
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
Brum Rum #431128 21/02/17 09:21 AM
Posting Desperado
Posting Desperado
Unless you go to the garage with aero screens on .
Brum Rum #431135 21/02/17 09:53 AM
Ray Offline
I think it is also illegal to drive with empty washer bottles.
Brum Rum #431181 21/02/17 02:15 PM
Thanks everyone, I'll have to raid the sewing box to find a needle!
Andy
Laser red 4/4
That's a valid point. I once got a series II Land Rover through the MOT with a failed wiper motor by folding the windscreen flat.
Not an option on a Mini I'll grant you.
~iw
2011 Morgan 4/4
1932 Austin 7 Chummy
Ray #431232 21/02/17 05:36 PM
Black Rat
Black Rat
Actually if it's raining it could lead to a prohibition notice !!!
Keith
2013 narrow bodied + 4 Ruby.
Brum Rum #431363 21/02/17 09:28 PM
Andy
Best to not use a needle as its tapered and often too big, the best thing to use is a single strand out of a wire brush.
Brum Rum #431369 21/02/17 09:46 PM
Check the bottle and filter for pond life. It's surprising what grows in washer fluid.
