Old Book
Topics49,940
Posts838,607
Posts: 1,338 |
Yes, any easy way? 30mins knocking the welds inside with a screwdriver & i have yet to remove one.
Posts: 2,539 |
I think you need to drill them as has been described in other posts. Only the cats could, in theory be removed with a hammer.
Posts: 6,538 |
Hi Q8 - good to see you back on TM
Neil
Posts: 2,539 |
Posts: 1,338 |
Posts: 1,338 |
Thanks Draggin...i did an Ok job, maybe with better tools & i can remove the baffle..or maybe drilling is the easier way [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/IMG_0498_zpsgszi5sq7.jpg.html]  [/url]][/url]
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
You need abetter tool kit....
It never inspires me if someone turn up to do a half decent job with a bag full of bed spanners and cold chisels.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Drilled mine last weekend 38mm hole saw on a long extension slow speed on heavy duty battery drill. all explained before on here... really very easy operation took longer to take pipes off than drilling. only front baffle removed much improved running ,not much elevation in noise either......... and cost £5 for bosch hole saw cheapest upgrade availible!
Posts: 1,338 |
So the pipes have 3 baffles/cat all together correct? 3 sections. I should remove the rear first & then the middle. or all three...?
Posts: 2,539 |
I may just remove the front, most restrictive one, and i'm leaving the cats.
