Posts837,985
Posts: 180 |
I did a 70 mile drive this evening, car driving fine, no sign of any handbrake issues. When I got home I went to apply the handbrake & noticed that the chrome tip at the top was very hot, however lower down the arm it was relatively cool. The car did not feel like the handbrake had been on when driving
I had the heater on but am not sure if this would have caused the issue.
Any ideas please
Thanks
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
given where the handbrake sits, it has to be the heater. There is no way that having the handbrake partially on would transmit heat to the top or even the bottom of the lever.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
The heater could easily do this, especially if you had the blower on and the temp at max. Try a similar trip with the heater off and I expect it will be OK.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Ha! Went through the same process with my gear lever knob. Definitely the heater vents..!!
Posts: 180 |
Hi All
Thanks for the speedy responses & reassurance - thought i was going to be in for some more wallet emptying
Ian
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Presuming you're talking Aero not Roadster (?), Mine does the same! I put it down to the heat from that gearbox, it's a Morgan they all do that Sir!...
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 38 |
Mine is the same, if it was Porsche a heated hand brake grip would be an extra cost option!
Posts: 180 |
Taffmog,
It's an Aero 8 Series 1. An interesting point about the gearbox which had occurred to me, but I'd have thought the lower part of the handbrake arm would get hot as well if it was the gearbox
Ian
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
If the bottom is cool it will be the heater vents
Aero 8 GTN #11
Yes agree Ian! But it's a Morgan! Mine's an S1 too, I suppose they all do that.....
