7 members (Redfate, B3MOG, MJF, Gaufridus, John07, MATTMOG, John Winn), 278 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
Page 5 of 5 1 2 3 4 5
Q
Q
Just google p0170 bad site front = fuel trim malfunction bank 1
P0173 = bank 2
P0170 - Fuel Trim Malfunction Bank 1 Possible causes Intake air leaks Faulty front heated oxygen sensor Ignition misfiring Faulty fuel injectors Exhaust gas leaks Incorrect fuel pressure Lack of fuel Faulty Mass Air Flow (MAF) sensor Incorrect Positive Crankcase Ventilation (PCV) hose connection What does this mean? Tech notes Dirty air filter, air filter housing or Mass Air Flow (MAF) sensor, or faulty MAF sensor are common causes for the P0170 code. What does this mean? When is the code detected? Fuel injection system does not operate properly or the amount of mixture ratio compensation is not correct Possible symptoms Engine Light ON (or Service Engine Soon Warning Light) Excessive Fuel Consumption P0170 Description With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios. In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
Read more: https://www.engine-codes.com/p0170.html
kirkusblog.com
1952 Ford 8N
Q
Q
Read this might help
http://www.talkmorgan.com/ubbthreads.php/topics/395341/Re:_Ugh...check_engine_light_i
Thanks guys for your input.
So it looks like my fuel mixture may be too lean. I am not really sure what I can do about this. My ProTune access is "read only", and I cannot make any fuel mapping changes myself. Looks like I may need to take it to the dealership for service.
As I mentioned at the start of this thread, the car seems to be running well. It idles smoothly, fires up on the first crank, and even power distribution.
Any advice???
Out of interest (and apologies if you said earlier in the thread) but what year is your M3W?
2012 G56 Stage 2 M3W
2007 Fiat Panda 100HP
1998 Lotus Elise (Cosworth Duratec)
1988 RF88 Van Diemen
It's a December production 2016.
Mmmm, interesting. The early cars seem to be more susceptible to this than newer ones (looks like there have been map changes, either to base map or range of adjustment before error flagging). Good luck in sorting it out!
