1 members (Taffmog), 394 guests, and 29 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
Page 1 of 7 1 2 3 4 5 6 7
#43365 20/04/10 07:42 PM
DaveW Offline OP
I thought that I would do a nice technical post for my 1000th post.
Is it really number 1000? thinking
Yes it is - grin2
The Sump..........
It looks like this:
The slope towards the offside is obvious and the strengthening hatching on the underside looks like a large Waffle.
The V6 Duratec was not designed to fit the Getrag gearbox, which is evident by some anomalies in the fixings. The first photo shows the offside edge of the sump, where it meets the bellhousing. On the Mondeo, the second open hole in this photo is used to fix the engine to the gearbox, but in the Morgan, an extra hole is drilled and a 10mm bolt is used, which is probably over-engineered, as it's only holding the two parts together.
This is how it looks from the bellhousing side, and you can see the mismatched shape. Also visible is the rear of the large waffle strengthener, and drain plug.
This is the same side of a Ford sump - and there's no third hole.
From the other side it looks like this, and the location of the missing third hole lacks re-inforcement. This is fixable, but more of that later - not today.......
On the nearside,this is the lower mount on the edge of the sump. The left hand hole is used on the Ford, but on the Morgan it can't be used. and neither can the bellhousing hole, so neither is used!!
From the other (bellhousing) side looking forward:
And here's the inside, with the baffle plate removed:
Note the centre oil pick up.
This is with the baffle plate fitted:
The front pan is shaped to drain oil to the rear, and to the offside - left side in this photo.
For now, that's all, because I'm still researching the situation. There are several different castings for Ford V6 Duratec sumps, and I'm hoping to get to the bottom of it.....
There's another dodgy DaveW pun to end on, for now. grin2
Another good post Sire!
I think I will stick with my older cars, however, I must have a closer look around RTA to see where 'corners' have been modified, 'fixing bodges' etc. have been made... grin2
Cheers,
Green & Grown Up
Green & Grown Up
Very Interesting. Is that your sump Dave. It would be interesting to get some photos of the inside of the Mulfab conversion. I wonder if Peter Mulberry would oblige? sherlock
Congrats on coming of age wine
very interesting.
Thanks, Dave
H3
Congratulations Dave on your 1000th, interestingly my posts have increased due to responding to your posts.
I am keen on the sump solution, it is too close to the ground for comfort.
DaveW Offline OP
Busy day today, so not much done to the Morgan. I did manage to take that Series1 specific nut & bolt out. It's unusual in having a 13mm bolt head and a 17mm nyloc nut.
This shows the sump flange with the bolt out, and you can see that the casting has been thickened up for the extra hole. You can also see that the bolt has chased some threads in the alloy. I'm guessing that the hole was drilled after the engine & gearbox were mated (from the rear). The hole is slightly undersize for that size bolt.
Here I'm using metal foil from a wine bottle to make a template for when I drill the extra hole in a spare sump. This foil is just right for keeping shape, so it can be moulded round the holes to transfer the location. More will follow on this next week.
DaveW Offline OP
I went to the Ford Dealer this morning to get a sump gasket and sump plug. This is how it went............
Me: 'DW' "I'd like a sump gasket for a V6 Duratec, and a sump plug please, like this one" I took sump plug with me as a precaution........
Young Stores Man: 'YSM' "We should have one of those - what's it for?"
DW: "a V6 Duratec"
YSM poised over keyboard..."what's the reg number"
DW: " I can't give you the reg number. It's not in a Ford. It's in a Morgan"
YSM now with blank expression as he scrolls down list of Fords......... "so what's it like then?"...nodding towards list of Fords on screen.
DW: "It's not a Ford - the reg number won't help"
DW produces phone with picture of Mog...."this is it"
YSM - suddenly gets it, but clearly has no idea what a Morgan is...."oh V6 Duratec did you say?"
DW: "Yes" - points at 3.0 V6 on drop down menu........
YSM "Nice car that - do you track it?"
DW: "No"
YSM finds sump picture. Two gaskets listed. Two sump plugs listed. "which is it?"
DW: "dunno"
YSM check stock - none in stock.
DW decides to go for later (post 2003) gasket.
YSM points out that sump plugs are 21mm, or 28mm.
DW: "I think it's 28mm"
YSM fetches ruler to measure my old plug. "What needs measuring?"
DW: "try the length". It's 28mm, but YSM not entirely convinced.
I order gasket and plug. Delivery next Thursday.
I'll let you know the outcome - obviously.
grin2
DaveW Offline OP
Well, I've prepped the spare sump for emergency use, and drilled the extra hole using the template.
Round the back it needs strengthening, and I've taken the easy route with JB Weld. This is so that when the nut is tightened, the filler will not compress, and stop the flange cracking.
Finished off........compare this with the photo in the first post.
Now the question of the sump bolt. There are two sizes, 21mm & 28mm - and I really can't see what difference it makes.......3051079 is the 28mm version, which comes in this large box. Look carefully at the integral neoprene washer and you'll see a small raised lip. This is what makes the seal, so providing it's undamaged, the bolt will be OK to re-use.
Next the gasket. Two were listed for the ST220, and I went for the post 2003. The part number for this is 4763355, BUT there's a big but............
I hope it's obvious in this photo. The gasket is a composite alloy/neoprene (and is over £40.........). The thickness is at least 2mm and if this were fitted to my Mog it would be visible as a sandwich plate. No gasket is visible. I therefore conclude that in order to increase clearance, a paper gasket is used on the Morgan.
FRANK - next time you visit the dealer, can you ask them about the sump gasket please. I bet it's paper, which means that we can make our own. laugh2
DaveW Offline OP
And now to the outside........
You should all know what the standard sump looks like.
Lets call it a 'full waffle' design.
The front is smooth....
My replacement Mondeo sump looks like this...........
Lets call this a 'quarter waffle' design:
This casting lacks the thick waffle plate, so has more clearance already. It also has two indents in the leading edge which are where the cast pillars are situated inside for the baffle plate. This sump carries the reference "99" F731-6675-BA F1. Apart from the obvious difference, it's the same as the standard sump.
My investigations showed that there are several different castings, so I sourced one which I will describe as 'quarter waffle and ribs': This carries the reference "98" F53E-6675-DB F2. There is a slight difference on the lower left corner - just a small mod to the flange - which is visible.
I've blown the sumps over with aluminium paint so the detail shows. The second sump is poorly cast with loads of small nodules. I've filed these off and polished the inside, as rough surfaces disrupt the oil draining back under the baffle plate. I may take this one to Mulfab to be shortened.
From all this, I conclude that the easiest option is to have a spare sump for emergency use. These can be found on e-bay, and I'll be happy to point you in the right direction if you send me a PM.
Next, have a sump shortened by Mulfab. For me that's easier if I get a spare sump shortened. I'd rather keep the original intact, unless it gets holed.
If I go down that route, I'll add the outcome onto this post.
I hope that helps all you lowriders. grin2 thumbs
Oh by the way, the internal baffle setscrews are 5/16" or 8mm.
The sump plug is 15mm. My standard sump has the reference: F960A 5L8E-6675-BB F4. The common part in all three is the '6675'.
Dave
Some very useful research, I am still considering a protection plate.
