9 members (Robbie, B3MOG, JMcL, gazum, +8Rich, High Hamster, Paulxj, MJF, DCH), 256 guests, and 53 robots.
+8Rich 75
Topics49,863
Posts837,554
numog #460319 10/07/17 01:35 PM
JJR Offline
Jochen,
I would gladly add post a picture if I could work out how to do it!
Best wishes,
John R Marchant
Plus Four JT10MOG "Florence"
Yes, but they were charging for it, initially. Policy now, who knows?
John, nice one, waiting for the piccies as Numog says. You must have a couple from the Wales trip (shame I couldn't put a yellow 4/4 in the background of those!).
Enjoy! Curborough taster next year? grin2
Drive on the Wild Side
Originally Posted By Hamwich
I thought Adrian had worked with the factory to resolve Roadster rev-hang problem? Was there not a re-map issued?
There is a detailed report on the forum on what was done and testing undertaken. It basically involves a replacement ECU from Aero Racing which effectively changes the mapping. The one supplied by Ford is locked down and cannot be flashed. The end result is a much more drivable car and improves it no end. At the time every 3.7 Roadster I drove which had not had the replacement ECU exhibited the rev hang. If you know what you are doing, you need to be a bit of a hooligan and accelerate very hard, it kicks in around 4500rpm, and change up gear quickly when over 4500rpm (do not fo this unless you have a clear road ahead)
and is also evident with overrun at 70mph and above with throttle lift off(once the engine is run in and has loosened up).
I'm not sure MMC still or can offer the replacement ECU, anyone wanting one would have to talk with them or through their dealer.
Adrian
I can only second Adrians words - i do have the Aero Racing ECU (+ their "insane" upgrade plus plus plus..) in my car - now it´s drivable as never before... BUT:
beware of the beast, it can & WILL bite badly!
+ it helps to have brakes & suspensions all round up to the new job......
drive 2015 Roadster 3.7
Roadsters are ace. Grin grin!
Welcome to the club.
