1 members (TeddyAds),
244
69
Topics49,867
Posts837,615
Posts: 94 |
I mean I have seen some who have inserted rear shocks with its own spring. (For example, to get higher ground clearance) Does anyone know of such a product?
----------- 2005 4/4.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
There are lots of tuning cocmpanies selling coil over suspension kits such as this one However having looked at my piccies of the Trad chassis I cant see how it would raise rear wheel travel that much. And you would of course need to specify spring and damper rates which are probably best got from someone who has already done the changeover.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
There is only 1 commercially available system for trad Morgans and that is the Suspension Supplies (ex Suplex) 5L rear . This comes as a complete kit with all the parts you need to convert the rear suspension from leaf springs with forward facing dampers , to coil-over-dampers, it has all the links. http://www.suspensionsupplies.co.uk/products/4593177137Peter (Gambalunga on here) runs with this system and is very pleased with it, another Peter uses it in Ireland (and I think Irish roads are probably as bad as Norwegian roads in the summer) and is also very happy. Look for old postings under the heading Suplex 5L This is not a cheap job, but everything is engineered to fit and could be done by a very competent home mechanic with good facilities. The somewhat similar system the factory uses on its race cars and the ARP4 is not available as a retro fit kit, and there is a decrease in ground clearance due to parts protruding below the bottom chassis rail.
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Andy -- it's Robbie actually, but I am very happy with the 5L rear suspension. Cuts out all bad surface small to medium bumps but you do, naturally, feel the big ones. Makes secondary Irish roads a pleasure!!!
Posts: 1,127 |
+1 in Germany  Fully recommended!!!!!!! Special thanks got to P.J.Ballard
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 228 |
.....and there's me thinking the "ride quality" was part of the the appeal
Andy
2011, 4/4, 2.0, 75th Anniversary 2016, VW Polo GTI 2012, BMW 520d Touring
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
+1 in Germany  Fully recommended!!!!!!! Special thanks got to P.J.Ballard +2 We have the slightly higher rated rear springs because we often carry a lot of luggage. Even with this setup it our Morgan has a more comfortable ride on all but the biggest bumps than  's new Polo. Ride height front and back is adjustable. The front depends on spacers and the back on the adjustable spring pre-load.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Last year on my Plus8 I replaced the Koni shocks with Rutherford AVOs from Tim Ayers. A good improvement. No height adjustments. One rear Koni was shot so I decided to change all 4. Fronts now set to 7 clicks after trial end error. Rears on softest but some adjustments to be tried. The Konis are good dampers but need removal to adjust on a bench. They are susceptible to large bumps breaking the adjusters internally hence losing adjustment ability.
