Topics49,861
Posts837,540
Posts: 2,539 |
Posts: 2,539 |
Posts: 2,539 |
Does anyone know if the belly pan aluminum has some sort of anti-corrosion coating on it? I have the car up in the air and it would be a perfect time to put something on it if it doesn't already exist.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Mines 2016 raw aluminium!
Posts: 2,539 |
Thanks Skully! Shark-hide it is then!
the misses said does that make her Mullder?
Posts: 582 |
Maybe paint with rattle can undercoat?
Posts: 2,539 |
Batts, i have a full quart of Sharkhide. I will probably do both sides of the floorpans.
Posts: 1,490 |
Batts, i have a full quart of Sharkhide. I will probably do both sides of the floorpans. Why?
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 367 Likes: 2
Posts: 367 Likes: 2 |
Whilst mine was up in the air when fitting a steel rear sprocket I took the opportunity to spray the entire underside with "Waxoil"
