7 members (DaveW, +8Rich, GrumpyPa, Ritchie B, Gordon D, Themorganeer, Stevo666), 245 guests, and 75 robots.
+8Rich 76
Topics49,861
Posts837,529
Jonny72
Page 3 of 5 1 2 3 4 5
Anybody got a spare old ally sprocket they want to throw my way? i like the sound(or no sound) of the supermax option!
Originally Posted By Dan_Lockwood
Am I missing something on the rear drum brake? I don't see any type of self adjuster on the rear drum brake.
There's a ratchet type self adjuster inside the drum, hidden behind one of the shoes. There's an​ inspection port to check and reset the ratchet but it is carefully arranged to be utterly inaccessible with the wheel in the car!
Calum, thanks for the information.
It would have been too simple to make it accessible, wouldn't it...
Dan
I was gonna ask the same, but not sure if the setup has or will have changed from the aluminium sprockets to what'll be on a 2018 model, since it looks like Wheels have changed too.
I see some with what looks like a version of a minilite on it, and then others with entirely different rear wheels. But that's off topic.
Good thought GTG.anybody done conversion on2016 back to ally? sherlock
Aluminum ones vanished years ago.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
cheers frown2
I did come across this thread: http://www.talkmorgan.com/ubbthreads.php/topics/217546/Re_rear_pulley
Granted when he picked that pulley up it was in the $100ish range now that link in there takes you to one that's about $300
That said I have found some where they're just blanks, they have a center bore and the teeth cut, but no bolt pattern cut. If this is a standard bolt pattern that's being used.
I wasn't certain what the rear tooth count was but if it's 65 like what I'm reading in other threads, there are a good number of Harleys and probably other bikes as well that use that same pulley size. I just can't imagine Morgan was having these custom cast and machined. So there's gotta be something out there similar already still that can be had on the cheap.
Hell hit up a local motorcycle shop and see if they have any pulleys of this size with thrashed teeth on em. Might just luck out.
Cheers G.T.G ill troll around see whats about!
FOR SALE
Supermax pulley
From Harley Softail 65 T 1 1/2"
Needs mod e.g. centre hole widening for M3W
Cost me $700 plus but by the time I got it the the M3W had moved on!
Check out Bay item number:
132454679525
was 2013 M3W,
now 2017 Pembleton VSport,
COMING SOON 2021 Pembleton V Sport
