6 members (Graham, G4FUJ, TBM, Ragnar, RedThree, Montegue, John Winn), 346 guests, and 90 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
#441528 07/04/17 07:05 PM
Hi I have a 1965 morgan plus 4 all of a sudden the choke needs to held to stay out, if you let it go it closes any help would be appreciated
Sounds like you have lost the clothes peg.
Costock, UK
Disco 5
My '63 +4 does not stay out either. I think it is designed that way. Another words pull choke (fuel enrichment)to start and release choke knob to run. If the choke (fuel enrichment jet) sticks open, put some petroleum jelly on the jet so it does not. There is a "Jet locking nut" that pushes against a cork washer. If the "Jet Locking Nut" is too tight the jet will stick. If it is too loose it will leak.
Make sure after +4 is started that this jet returns to its normal position. It often sticks and the +4 runs too rich.
Read Your manual on SU Carbs. There are a lot of little details that must be attended to properly for it to operate properly.
Button
Hang your man bag on it. hide
The jet locking nut is used to centralize the jet on the needle. I have found that when the choke was too hard to pull the jets needed to be re-centered, but I've never had it work the other way.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
Ray Offline
I have similar on the +8, should be pull and turn to stay on, but it only works on certain days of the week...strange.
Yes: That is true. The locking nut and cork washer assy. also seal the jet from leaking fuel. The trick is to center the jet and tighten the jet locking nut just enough to prevent fuel from leaking out but not so tight that the jet does not freely move up and down while choking. Not always easy to do. In the case of H-6 SU's the word is not "Choking" but "Fuel enrichment". Picky, Picky!
Button
I think I solved it the twist to the right was the way to go thanks for all the input
Ha! Ha!
Button
I recall some chokes were "twist" to stay out after pulling. Quarter turn or so.
