Topics49,917
Posts838,224
Posts: 3 |
Hello everyone.
I'd be grateful if someone could advise me what make and type of grease they use for the front suspension.
I have 2014 4/4.
Thanks very much
Posts: 3,643 |
I first used Comma CV Lith Moly grease from Halfords.
Adrian on here suggested Lucas Red 'n' Tacky which I am using at present. I will swop back to the Comma grease once the Red n Tacky runs out. Main reason is that when I get the car serviced the dealer uses Lith Moly so no point in having a mix in my view.
Posts: 37,492 Likes: 994
Posts: 37,492 Likes: 994 |
Another yes for Comma Moly from Halfords.
Posts: 305 |
Lucas Red n Tacky as recommended by many on TM . When getting it serviced I get my dealer to use my grease gun .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
The thicker the better,at MOT time.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I use Comma king pin grease, no problems as yet.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,943 |
Not sure it makes any difference. I have used Molloy, White Lithium, Boat axle grease, wheel bearing grease, CV grease. And probably many more. Just use some of this stuff for sure and regularly. Argue with Me if You like but if I am wrong I probably have used the wrong grease on 4 Mogs for almost 40 years. Yes I do drive them a lot. For the last 10 years I have used Chrome King Pins and Vesconite Bushes and in excess of 50,000 miles.
I think who ever is using a semi liquid grease/oil maybe the best solution of all. But I have not tried it myself.
Button
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
I'm with Button, I really don't think it makes a hap'orth of difference which grease one uses, so long as one does it regularly and swaps to hardchrome kingpins as soon as the originals wear out - which won't be very long if one neglects the greasing  But a Moly grease is a good choice. I'm currently using Red'n'Tacky, which seems a bit thicker to me.
Posts: 2,782 Likes: 5
Posts: 2,782 Likes: 5 |
I use Penrites fluid grease designed for steering boxes, it's not quite a solid grease at normal temperatures, seems to get to the right places but is thick enough not not leak everywhere.
Oil is a better lubricant if you can keep it in so it seems a good compromise, but agree any grease is better than none.
You'll hear advice about being careful not to overdo it and risk it getting on brake discs. To be honest you'll have to go some to create enough excess grease to do that but little and often is the key.
Steve 2008 4/4 1.8 Duratec
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Using differing colour greases is very handy, you can easily spot when you have pushed the old out by the colour change.
